Two clock domains in the same procces
The module clock is CLK = 120 Mhz.
The milliseconds counter clock is MS_CLK = 100 Mhz.
I count milliseconds
constant TICKS_FOR_1MS : std_logic_vector(31 downto 0) := X"000186A0"; --100 Mhz process (MS_CLK) begin if (rising_edge(MS_CLK)) then if (count_reset= '1') then ticks_counter <= (others => '0'); ms_counter <= (others => '0'); else ticks_counter <= ticks_counter + '1'; if (ticks_counter = TICKS_FOR_1MS) then ticks_counter <= (others => '0'); ms_counter <= ms_counter + '1'; end if; end if; end if; end process;
The problem is - the signal count_reset is changed in another process that clocked with CLK. How to synchronize those signals?
- EngWei_O_Intel
Hi there
I can't fully visualize how the count_reset being used in another process, from your description, seems like you are changing a signal in two different processes which is not a common practice.
thanks,
Eng Wei
- EngWei_O_Intel
Hi user
We do not receive any response from you to the previous reply that have been provided. This thread will be transitioned to community support. If you have a new question, feel free to open a new thread to get the support from Intel experts. Otherwise, the community users will continue to help you on this thread. Thank you.
Eng Wei
