manpreet_1604
4 years agoTiming Requirements not met
Hi All,
I am using Altera CPLD "EPM7064" as a Replacement of Atmel "ATF1504" the original code was generated and tested for ATF1504 in "pro chip designer tool" using Verilog, when the same code is...
Nurina
4 years agoHi,
We did not receive any response to the previous reply provided, thus I will put this case to close pending. Please post a response in the next 15 days to allow me to continue to support you. After 15 days, this thread will be transitioned to community support. The community users will be able to help you with your follow-up questions.
P/S: If you like my comment, feel free to give Kudos. If my comment solved your problem, feel free to accept my comment as solution!
Nurina
- manpreet_16044 years ago
Sorry for the delay, I was out of station from last few days so unable to reply.
please check the attached code file
