arno_va's avatar
arno_va
3 years ago
Timing failure with external synchronous SRAM
I have a Cyclone V FPGA interfaced with an external synchronous (ZBT) SRAM. The FPGA is clocked with a 100 MHz XO, which is passed through the FPGA and forwarded/outputted to my SRAM as its clock. Ob...
  • RichardT_altera's avatar
    3 years ago
    Sorry for the delay in response. Been taking some time to solve the timing violation.
    For bidirectional I/O, they are analyzed as inputs and outputs, so they usually have both set_input_delay and set_output_delay assignments.
    These sdc below in the project could be reason we got the huge negative slack. The tool analyze that the Data Arrival Path goes from clk_100_in -> sram_clk_out -> sram_clk_inout (o) -> external device -> sram_clk_inout (i) and then back to RAM block. This make it a very long timing path.
    set_input_delay -clock sram_clk_out -min 1.3 [get_ports {sram_data36_inout*}]
    set_input_delay -clock sram_clk_out -max 3 [get_ports {sram_data36_inout*}]
    With that, I create a virtual clock and add the input and output delay constraint to the sram_data36_inout*:
    create_clock -name {sram_clk_ext} -period 10.000ns
    set_input_delay -clock sram_clk_ext -min 1.3 [get_ports {sram_data36_inout*}]
    set_input_delay -clock sram_clk_ext -max 3 [get_ports {sram_data36_inout*}]
    set_output_delay -clock sram_clk_out -min 1.3 [get_ports {sram_data36_inout*}]
    set_output_delay -clock sram_clk_out -max 3 [get_ports {sram_data36_inout*}]
    I also disable all the location assignment so that the fitter can place and route without being constraint, to meet the timing.
    Attached the modified project. Though there is a timing violation of sram_address21_out and I believe it can be solved by tweaking the -max value to 1.0.
    set_output_delay -clock sram_clk_out -max 1.0 [get_ports {sram_*_out*}]
    Richard Tan
Recent Discussions
