16 years agoTimeQuest .sdc constraints for EPCS (ALTASMI_PARALLEL megafunction)
Hi all,
I'm using the ALTASMI_PARALLEL megafunction to access a EPCS16 device at 25MHz (active serial) on a Cyclone III device. The EPCS16 is 2 centimeters away from the FPGA (very small PCB traces). In order for this to work I had to select "Use and user I/O" on all four EPCS interface pins. As a side effect I now need to properly constrain these four pins in TimeQuest. I know that the signals are "source-synchronous output" because the clk is outputted from the FPGA (AN433) but nevertheless this seams tricky because the data in using falling edge and dataout uses riding edge. Has anyone already did that ? Can you share the file ?16 Replies
No, that is the problem. It seams they do not work with it but also do not work without it.
I filed a service request with altera, let's see what they say about it. - Altera_Forum
--- Quote Start --- ngcreese, you are correct. I had a copy paste error in the forum, (I corrected it now) but the .sdc file that I used with TimeQuest was correct. So Your tip did not help me. --- Quote End --- No worries man. Glad your constraints are working for you without this skew constraint. - Altera_Forum
ngcreese, you are correct. I had a copy paste error in the forum, (I corrected it now) but the .sdc file that I used with TimeQuest was correct(did not have the error I had in the forum). So Your tip did not help me. :(
There seems to be two different clocks in these statements:
# EPCS clk output create_generated_clock -name {epcs_dclk} -source [get_pins {pll|altpll_component|auto_generated|pll1|clk[1]}] [get_ports {*ALTERA_DCLK}] set_max_skew -from [get_clocks {clk_epcs}] -to [get_ports {*ALTERA_DCLK}] 1 Was that intended? I would think you might have ment something more like this: # EPCS clk output create_generated_clock -name {clk_epcs} -source [get_pins {pll|altpll_component|auto_generated|pll1|clk[1]}] [get_ports {*ALTERA_DCLK}] set_max_skew -from [get_clocks {clk_epcs}] -to [get_ports {*ALTERA_DCLK}] 1 In order for the "set_max_skew" command to be applied to the design by the tools. - Altera_Forum
When I use the "set_max_skew" like shown above I get:
--- Quote Start --- Warning: No path is found satisfying assignment "set_max_skew -from [get_clocks {clk_epcs}] -to [get_ports {*ALTERA_DCLK}] 1.000 ". This assignment will be ignored. --- Quote End --- When I remove the "set_max_skew" line I get: --- Quote Start --- Unconstrained Output Port: asmi_slave:asmi_inst|asmi:asmi_inst|asmi_altasmi_parallel_t852:asmi_altasmi_parallel_t852_component|cycloneii_asmiblock3~ALTERA_DCLK No output delay, min/max delays, false-path exceptions, or max skew assignments found. This port has clock assignment. Unconstrained Output Port Paths: pll|altpll_component|auto_generated|pll1|clk[1] No output delay, min/max delays, false-path exceptions, or max skew assignments found. This port has clock assignment. --- Quote End --- So how do I fix it ? Is it a bug in Quartus ? - Altera_Forum
Here is what I got so far:
--- Quote Start --- # Create external XTAL Clock input create_clock -name {CLK_50MHZ_PLL[4]} -period 20.000 -waveform { 0.000 10.000 } [get_ports {CLK_50MHZ_PLL[4]}] # Create PLL Generated Clocks 100MHz and 25MHz create_generated_clock -name {clk} -source [get_pins {pll|altpll_component|auto_generated|pll1|inclk[0]}] -duty_cycle 50.000 -multiply_by 2 -master_clock {CLK_50MHZ_PLL[4]} [get_pins {pll|altpll_component|auto_generated|pll1|clk[0]}] create_generated_clock -name {clk_asmi} -source [get_pins {pll|altpll_component|auto_generated|pll1|inclk[0]}] -duty_cycle 50.000 -multiply_by 1 -divide_by 2 -master_clock {CLK_50MHZ_PLL[4]} [get_pins {pll|altpll_component|auto_generated|pll1|clk[1]}] # Constrain the *ALTERA_DCLK output port from the ALTASMI_PARALLEL megafunction set_min_delay -from [get_pins {pll|altpll_component|auto_generated|pll1|clk[1]}] -to [get_ports {*ALTERA_DCLK}] 5.1 set_max_delay -from [get_pins {pll|altpll_component|auto_generated|pll1|clk[1]}] -to [get_ports {*ALTERA_DCLK}] 7.1 # EPCS clk (virtual clock at the input pin of the EPCS device) create_generated_clock -name {clk_epcs} -source [get_pins {pll|altpll_component|auto_generated|pll1|clk[1]}] [get_ports {*ALTERA_DCLK}] set_max_skew -from [get_clocks {clk_epcs}] -to [get_ports {*ALTERA_DCLK}] 0.2 # Set Clock Uncertainty derive_clock_uncertainty # Board trace delays set max_btd 0.2 set min_btd 0.1 # Set Input Delay, see Table 3-17 of the EPCS Datasheet# ************************************************************** set_input_delay -max [expr $max_btd +8 +$max_btd] -clock { epcs_dclk } -clock_fall [get_ports {*ALTERA_DATA0}] set_input_delay -min [expr $min_btd +5 +$min_btd] -clock { epcs_dclk } -clock_fall [get_ports {*ALTERA_DATA0}] # Set Output Delay, see Table 3-16 of the EPCS Datasheet# **************************************************************# Do not violate tSLCH (t ce setup) set_output_delay -add_delay -max -clock [get_clocks {clk_epcs}] [expr +$max_btd +10 -$min_btd] [get_ports {*ALTERA_SCE}]# Do not violate tCHSL (t ce hold) set_output_delay -add_delay -min -clock [get_clocks {clk_epcs}] -[expr +$min_btd +10 -$max_btd] [get_ports {*ALTERA_SCE}] # Do not violate tDVCH (t data setup) set_output_delay -add_delay -max -clock [get_clocks {clk_epcs}] [expr +$max_btd +5 -$min_btd] [get_ports {*ALTERA_SDO}]# Do not violate tCHDX (t data hold) set_output_delay -add_delay -min -clock [get_clocks {clk_epcs}] -[expr +$min_btd +5 -$max_btd] [get_ports {*ALTERA_SDO}] --- Quote End ---
