16 years agoTimeQuest .sdc constraints for EPCS (ALTASMI_PARALLEL megafunction)
Hi all, I'm using the ALTASMI_PARALLEL megafunction to access a EPCS16 device at 25MHz (active serial) on a Cyclone III device. The EPCS16 is 2 centimeters away from the FPGA (very small PCB ...
16 years ago --- Quote Start --- ngcreese, you are correct. I had a copy paste error in the forum, (I corrected it now) but the .sdc file that I used with TimeQuest was correct. So Your tip did not help me. --- Quote End --- No worries man. Glad your constraints are working for you without this skew constraint.
