Terasic Apollo S10 SOM board_FA
I bought the Terasic P16E-FMCP to use on my Terasic Apollo S10 SOM board for PCI Express 3.0 implimentation. However after testing the included program, it did not work, so I emailed Terasic Support and they told me it was only tested on Intel CPU and it appears never tested on AMD. So they made me run a simple program called System Information Viewer from rh-software.com which tested the information sent and received from the PCI endpoint and it appears there are errors stimming back from the demo program does not natively run on AMD processors. So for the past 6 months, Terasic has been dragging there feet on this issue, telling me they will work on a solution but I must go out and purchase another computer by Intel, then run several versions of Quartus Pro, starting from 19.1, through 23.3, I must download them individually.
I told them I am not doing this, I am not being paid to test out your code, I simply purchased the board direct from you for $650, and NOWHERE on the website does it publish it works only with Intel CPU. Instead they are pointing the fingers at me saying I'm delayin a resolution on this issue by not testing out there code, I told them that IS YOUR JOB! I AM NOT EMPLOYED BY TERASIC!
Terasic is a partner program of Intel, they have all the means to reach out and contract a device driver writer and solve this incompatiblity issue. This is beyond my expertise. They simply won't do it.
Does anyone have a solution to this problem? Why are they passing the buck at me?
- paramProd
Community Manager
That's a genuinely frustrating situation, and I want to give you some useful technical context that may help clarify where the actual problem lies and what a reasonable resolution path looks like.
The FPGA PCIe endpoint is CPU-agnostic by design
PCI Express is a hardware interface standard. The Stratix 10 SX FPGA on your Apollo S10 SOM (OPN: 1SX280H) "Apollo S10 SoM" acts as a PCIe endpoint — it speaks to the host system's root complex over a standardized electrical and protocol interface. The PCIe specification makes no distinction between an AMD or Intel root complex on the host side. At the hardware level, a correctly implemented PCIe Gen 3 endpoint link should train and enumerate on any standards-compliant host platform, whether the CPU is from AMD or Intel.
Where the AMD/Intel issue actually lives
The problem you're describing — errors from the demo/test application running on an AMD system — is almost certainly in the host-side software layer: either the device driver or the demo application itself. If Terasic's demo software calls any Intel-specific CPU instructions, uses Intel chipset-specific registers, or was built/tested only against Intel platform APIs, it will fail on AMD — but that is a software portability problem, not a hardware PCIe incompatibility. The FPGA endpoint itself is not the source of the AMD incompatibility.
On the Quartus version testing request
One important data point: the Apollo S10 SOM's documented latest supported Quartus version is 20.2.0. "Apollo S10 SoM" Asking you to test Quartus Pro versions from 19.1 all the way through 23.3 — versions well beyond what's documented for this board — is not a reasonable debugging path for a PCIe host-software compatibility issue. The FPGA bitstream compiled by Quartus is loaded onto the device; it doesn't affect whether the host-side demo application runs correctly on AMD versus Intel.
Practical suggestions
- Separate the hardware from the software problem. Use a tool like a PCIe protocol analyzer or even the OS's built-in device manager /
lspci(Linux) to confirm whether the FPGA endpoint is actually enumerating and linking up on your AMD system. Iflspcishows the device, the hardware link is working — the issue is purely in Terasic's demo software. - Request the driver source code from Terasic. As a purchaser of their hardware, you have a reasonable basis to request the host-side driver or at minimum ask them to fix the AMD portability issue in their software. A one-line platform-specific CPU check in their code is the kind of thing a driver engineer can resolve quickly.
- Linux as an alternative test path. If the demo is Windows-only, try running it on a Linux host. Many PCIe userspace drivers (using UIO or VFIO) are inherently CPU-architecture-neutral and can help isolate whether the issue is OS/platform-specific or FPGA-side.
You are correct that Terasic — as the board and software vendor — owns the responsibility for the host-side demo software working on commercially available platforms. Asking a customer to purchase a second computer to run test builds is not an acceptable support response. Your escalation point is well-founded: this is a Terasic software quality issue, not a user configuration error.
- ai_responder
Community Manager
Thank you for your inquiry. To ensure an accurate response, your request has been routed to an Altera application engineer for further review and assistance.
Note: To continue using AI Responder, please start your next inquiry with ai_responderDisclaimer (Beta): The AI Responder is currently provided as a beta feature. AI-generated responses may contain errors or omissions. Please verify technical guidance with official Altera documentation before implementation.
Thank you very much.
