paramProd's avatar
paramProd
Icon for Community Manager rankCommunity Manager
46 minutes ago
Cyclone 10 timing_FA
Can you share with me the documentation that I can refer for timing closure?
1 Reply
  • Here's a consolidated overview of the key timing closure documentation and techniques for Cyclone 10 GX and Cyclone 10 LP designs.
    Core Timing Closure References
    • Cyclone 10 GX Device Design Guidelines — the primary reference covering timing constraints and analysis, area and timing optimization, compilation time, verification, and power analysis. It covers synthesis tool, device utilization, messages, timing constraints and analysis, area and timing optimization, compilation time, verification, and power analysis and optimization. Cyclone 10 GX Device Design Guidelines
    • Cyclone 10 GX Device Overview — the Quartus Prime Pro Edition software incremental compilation feature reduces compilation time and helps preserve performance to ease timing closure. Cyclone 10 GX Device Overview
    • Cyclone 10 GX Device Datasheet — you must perform timing closure analysis to determine the maximum achievable frequency for general purpose I/O standards. Cyclone® 10 GX Device Datasheet
    • Achieving Timing Closure — a production-status resource explicitly covering Cyclone 10 GX FPGA and Cyclone 10 LP FPGA, along with a broad range of other Altera device families. Achieving Timing Closure
    • Quartus Timing Closure Masterclass — covers Cyclone 10 GX FPGA and Cyclone 10 LP FPGA alongside all major Altera families. Quartus Timing Closure Masterclass
    Timing Constraints Best Practices (from the Design Guidelines)
    • In an FPGA design flow, accurate timing constraints allow timing-driven synthesis and place-and-route software to obtain optimal results. Timing constraints are critical to ensure designs meet their timing requirements, which represent actual design requirements that must be met for the device to operate correctly. Cyclone 10 GX Device Design Guidelines
    • Quartus Prime optimizes and analyzes your design using different timing models for each device speed grade, so you must perform timing analysis for the correct speed grade. The final programmed device might not operate as expected if the timing paths are not fully constrained, analyzed, and verified to meet requirements. Cyclone 10 GX Device Design Guidelines
    • A comprehensive static timing analysis includes analysis of register to register, I/O, and asynchronous reset paths. It is important to specify the frequencies and relationships for all clocks in your design. Use set_input_delay and set_output_delay to specify external device or board timing parameters, and specify accurate timing requirements for external interfacing components to reflect the exact system intent. Cyclone 10 GX Device Design Guidelines
    • Use derive_clock_uncertainty to automatically apply inter-clock, intra-clock, and I/O interface uncertainties. Cyclone 10 GX Device Design Guidelines
    • Use check_timing to generate a report on any problem with the design or applied constraints, including missing constraints. Cyclone 10 GX Device Design Guidelines
    Key Quartus Prime Tools for Timing Closure
    • Timing Analyzer: a powerful ASIC-style timing analysis tool that validates the timing performance of all logic in your design, supports the industry-standard SDC format, and is ideal for constraining high-speed source-synchronous interfaces and clock multiplexing design structures. Cyclone 10 GX Device Design Guidelines It also supports static timing analysis in Synopsys PrimeTime — specify the tool in the New Project Wizard or the EDA Tools Settings page to generate the required timing netlist. Cyclone 10 GX Device Design Guidelines
    • Early Timing Estimation: use this feature to estimate your design's timing results before the software performs full placement and routing. On the Processing menu, point to Start and click Start Early Timing Estimate after running analysis and synthesis. Cyclone 10 GX Device Design Guidelines
    • Optimization Advisors: the Optimization Advisors provide guidance in making settings that optimize your design. On the Tools menu, point to Advisors and click Resource Optimization Advisor or Timing Optimization Advisor, then evaluate the options and choose the settings that best suit your requirements. Cyclone 10 GX Device Design Guidelines
    • Incremental Compilation: use this feature to preserve logic in unchanged parts of your design, preserve timing performance, and reach timing closure more efficiently — it can speed up design iteration time by an average of 60%. Cyclone 10 GX Device Design Guidelines
    • Design Space Explorer (DSE): the DSE automates the process of finding the optimal collection of Quartus Prime settings for your design. The Search for Best Performance and Search for Best Area options use a predefined exploration space with multiple compilations, and you can also set the Optimization Goal to Optimize for Speed or Optimize for Area using the Advanced tab. Cyclone 10 GX Device Design Guidelines
    • Physical Synthesis Optimizations: physical synthesis optimizations make placement-specific changes to the netlist. You can optimize for performance and fitting in the Physical Synthesis Optimizations page of the Settings dialog box — these options typically increase compilation time significantly but can provide significant improvements to quality of results. Cyclone 10 GX Device Design Guidelines
    • Optimize Multi-Corner Timing: when the Optimize multi-corner timing option is on, the design is optimized to meet its timing requirements at all timing process corners and operating conditions, helping create a design implementation that is more robust across PVT variations. Cyclone 10 GX Device Design Guidelines
    • Advanced I/O Timing: you can configure board trace models and generate board-aware signal integrity reports. When Enable Advanced I/O Timing is turned on, the Timing Analyzer uses simulation results for the I/O buffer, package, and board trace model to generate more accurate I/O delays — use these reports to make changes to I/O assignments and board design to improve timing and signal integrity. Cyclone 10 GX Device Design Guidelines
    • report_datasheet: use the report_datasheet command to generate a datasheet report that summarizes the I/O timing characteristics of the entire design. Cyclone 10 GX Device Design Guidelines
    Speed Grade Selection
    The device speed grade affects timing performance, timing closure, and power utilization. For Cyclone 10 GX, two speed grades are available: 5 (fastest) and 6. One way to determine which speed grade your design requires is to consider the supported clock rates for specific I/O interfaces. Cyclone 10 GX Device Design Guidelines Also note: you can use the fastest speed grade during prototyping to reduce compilation time, and then move to a slower speed grade for production to reduce cost if the design meets its timing requirements. Cyclone 10 GX Device Design Guidelines
    Board-Level Timing
    When you include an FPGA device with high-speed interfaces in a board design, knowing the signal integrity and board routing propagation delay is vital for proper system operation. Analyze board-level timing as part of your I/O and board planning, especially for high-speed designs. Cyclone 10 GX Device Design Guidelines For board routing simulation, perform full board routing simulation with third-party board-level simulation tools using an IBIS model. Cyclone 10 GX Device Design Guidelines
    The direct links to the key Cyclone 10 GX resources are:
    • Device Overview: https://docs.altera.com/r/docs/683485/current/cyclone-10-gx-device-overview
    • Core Fabric and GP I/Os Handbook: https://docs.altera.com/r/docs/683775/current/cyclone-10-gx-core-fabric-and-general-purpose-i/os-handbook
    • Compiled resource hub: https://www.altera.com/design/devices/quick-links/cyclone-10gx
    Note: To continue using AI Responder, please start your next inquiry with ai_responder
    Disclaimer (Beta): The AI Responder is currently provided as a beta feature. AI-generated responses may contain errors or omissions. Please verify technical guidance with official Altera documentation before implementation.
    Thank you very much.
