LHinC1's avatar
LHinC1
6 years ago
Stratix 10 PHYLite avalon bus avl_readdata seems to be synthesized away
Hi Altera AE ,
We are working on a design on Stratix 10 using PHYLite library.
We previously use Arria 10 PHYLite in our last project, it was smooth and we didn't encounter any problem in Arria 10.
In Stratix 10, the waitrequest signal was stuck at high all the time
before we issue any command to the avalon bus after reset.
We solved this by issuing a number of dummy write commands to avalon bus, the waitrequest signal returns to 0.
We got help from Altera AE on this issue, and now we see another issue thus I raise a post here.
After solving the waitrequest issue, we continue to read the basic information from the avalon bus,
we can see the readdata_valid pulse in signal tap but avl_readdata is always 0
when we read the address 0x05000024.
We don't see anything wrong in the RTL, but we see that the avl_readdata is always 0.
Until we make an irrelevant change to the code, the avl_readdata becomes normal again such that the readdata_valid looks the same as what it is when the avl_readdata is 0.
It is so weird, we spent a couple of days on this.
Please help us on this, we have been stuck on the avalon bus communication for 3 months.
FYI : we are using quartus version 19.3
Samson
    • LHinC1's avatar
      LHinC1
      Hello Rashmi,
      Yes, our distributor FAE has provided this workaround to us on Quartus version 19.3,
      we tried it already, it doesn't help, the result is the same.
      Samson
  • Rashmi1's avatar
    Rashmi1
    HI Samson,
    Thank you for providing all the required information. I have been consulting with our Engineering team for further debug . Based on the issue criticality we decided to escalate the issue for our Factory Apps team to further debug, we suspect something more going on which requires in depth review.
    I will keep you updated .
    Rashmi
  • Rashmi1's avatar
    Rashmi1
    also, can you reproduce the issue in simulation ?
    • LHinC1's avatar
      LHinC1
      Hi Rashmi,
      We normally do a simulation with basic building blocks.
      We haven't done any simulation with the whole design, this would be very time-consuming.
      Samson
  • Rashmi1's avatar
    Rashmi1
    Hi Samson,
    Do you mind to share what’s the irrelevant code change to fix the avl_data 0?
    For this avl_data is 0, I would think we can check the pin assigned by checking the correct lane or pin addresses that are assigned correctly. You can refer to this PHYlite wiki page to get the correct addresses.
    Rashmi
    • LHinC1's avatar
      LHinC1
      Hello Rashmi,
      We just changed a single line in our design, then we get the following result.
      I attached a picture "SignalTap.png".
      We just changed one single line in a state machine that interfaces with the avalon bus.
      The difference is shown in "before (failed).png" and "after (working).png".
      I also attached my code "TC4200ST_L_19_3_20200728.qar", this one is the working one.
      Samson
  • Rashmi1's avatar
    Rashmi1
    Hi Samson,
    It seems like the write transaction isn’t completing prior to the read transaction.
    How are you verifying if transfer of all the write data for the write transaction?
    Rashmi
    • LHinC1's avatar
      LHinC1
      Hello Rashmi,
      We are accessing the PhyLite through the Avalon bus,
      We read the indirect address from the address 0x05000024.
      It does not require any write command before reading data, is it correct?
      I attach the table copied from Phy Lite user guide.
      We did the same thing in our last Arria 10 design.
      I encounter this problem when I move our design to Stratix 10 device.
      Samson
  • Rashmi1's avatar
    Rashmi1
    Thank you. I will work on reproducing the issue and get back to you shortly.
    • anat's avatar
      anat
      What is the solution for this issue
    • LHinC1's avatar
      LHinC1
      Hello Rashmi ,
      Excuse me, it is very urgent for us, do you have any update?
      Thank you so much.
      Samson
  • Hi Samson,
    Thank you for reaching out to Intel Forum. My name is Rashmi.
    can you please provide me with project to reproduce the issue at my end also the screen shots of signal taps of the signals .
    Rashmi
