Stratix 10 MX HBM2 Addressing with Avalon-MM user side interface
I am currently trying to create a design that uses the HBM2 Avalon-MM user-side interface.
I have started with this Intel Forum design, which has worked and has been quite helpful.
However, when I am trying to adapt the design to my needs, I am faced with a few confusions.
In particular, I am using a msGDMA and a write master to convert an Avalon stream to an Avalon MM format. The write DMA master is interfaced with the HBM2. I have done something similar and instantiated a read DMA master, interfaced to the same channel (and pseudo-channel) of the HBM2.
I am monitoring the read and writes of the DMAs on SignalTap. My writes seem to work perfectly. And at a given incrementing address, 256-bit writes are captured by the HBM2.
Once this is complete, the read master is triggered. Unfortunately, the read master doesn't show the data that I would expect. Writing a fixed pattern on addresses 0x0-0xFFF would only yield some of the reads to have the same constant pattern, while other reads have some erroneous bits.
My question is that if I was to write on address 0 a particular 256-bit word, why is that when I am reading address 0, not all the 256 bits are as expected?
Is there something I am overlooking with regards to addressing in the HBM2? The documentation currently has very limited support for Avalon MM use cases.
Another puzzling thing is that when I connect a write DMA to one pseduo-channel and the read DMA to another pseduo-channel of the same HBM2 channel, I get completely different reads from what I had written? Is this expected behavior? Can one not access the memory of the same channel via either of the pseduo-channels?
Thank you for the help
- AdzimZM_Altera
We do not receive any response from you to the previous reply that I have provided. This thread will be transitioned to community support. If you have a new question, feel free to open a new thread to get the support from Intel experts. Otherwise, the community users will continue to help you on this thread. Thank you.
- AdzimZM_Altera
Hello Sir,
Do you have any feedback regarding to my previous comment?
Adzim
- AdzimZM_Altera
Hi Sir,
I would like to replicate the issue from my side.
Maybe you can share a simple design that can reproduce the issue and provide the step as well.
Adzim
- s10M
Hello Adzim,
One of the workarounds suggested by the KDB was to use Intel® Quartus® Prime Pro Edition software version 21.1 or higher, which I have done.
Unfortunately, the problem still persists.
i.e. when both read and write Avalon masters are connected to the HBM2, reads are not as expected when reading a particular address. A few bits are always incorrect in consecutive reads.
Furthermore, when the two Avalon masters are connected to different pseuo-channels (of the same channel) of the HBM2, the reads are completely different.
Would appreciate it if you could verify if this is expected behavior.
Thank you.
- AdzimZM_Altera
I would encourage you to use the workaround from the KDB.
Please let me know the result of the testing.
Adzim
- s10M
Hello Adzim,
Thank you for directing me to the KDB.
Unfortunately, I have migrated my design to Quartus 21.1 but the problem still persists.
Thank you.
- AdzimZM_Altera
I think you can refer to this KDB:
https://www.intel.com/content/www/us/en/support/programmable/articles/000086781.html
Please let me know if that help.
Adzim
