s10M
4 years agoStratix 10 MX HBM2 Addressing with Avalon-MM user side interface
I am currently trying to create a design that uses the HBM2 Avalon-MM user-side interface.
I have started with this Intel Forum design, which has worked and has been quite helpful.
s10M
4 years agoHello Adzim,
One of the workarounds suggested by the KDB was to use Intel® Quartus® Prime Pro Edition software version 21.1 or higher, which I have done.
Unfortunately, the problem still persists.
i.e. when both read and write Avalon masters are connected to the HBM2, reads are not as expected when reading a particular address. A few bits are always incorrect in consecutive reads.
Furthermore, when the two Avalon masters are connected to different pseuo-channels (of the same channel) of the HBM2, the reads are completely different.
Would appreciate it if you could verify if this is expected behavior.
Thank you.
