8 years ago
Strange PLL Clock causing me failing paths in cyc V design
Dear all,
TimeQuest is warning me of a failing path in my Altera Cyclone V FPGA design.
It says failing path with:
Slack______From Node ____________________________________ ____to Node __________Launch Clock ____________________________________________________________________________Latch clock____Relationship __Clock Skew ___Data Delay
-9.115 ____    io_control:io_control_inst1|data_out _______    dq _______    pll_inst_100|pll_100_inst|altera_pll_i|general.gpll~PLL_OUTPUT_COUNTER|divclk ______  clk_100____    10.000 ____    -10.144______2.901
I wonder what is the problem here and what clock divclk is? The entity io_control flops the data from inside the design and tristating it to dq. dq is an Input / Output Port at the top level design.
IO_control has clock input clk_100. clk_100 is routed globally through the design with an ALTCLKCTRL. The clk_100 is feed to external hardware via ALTDDIO which is consuming dq.
Here is the code of IO_control:
flopping_data_out_proc : process(CLK, RESET)begin
    if (RESET = '0') then
        data_out <= (others => '0');
    elsif (rising_edge(CLK)) then
        data_out <= Fin_DATA_ram;    -- comes from inside FPGA Design
    end if;
end process flopping_data_out_proc;
mux_data_out_proc : process(slrd_en, data_out)
begin
    if (slrd_en = '0') then
        DATA <= data_out;        -- DATA is output of IO Control and wired to DQ
    else
        DATA <= (others => 'Z');
    end if;
end process;
Can somebody enlighten me if this is a critical issue? I set all needed timing constraints but wonder if I had to add a multicycle path or set false path between these clocks?
It is noticeable that the fitter puts out a warning during fitting:
Warning (332049): Ignored create_clock at SDC1.sdc(2): Incorrect assignment for clock.  Source node: CLOCK_50_B5B already has a clock(s) assigned to it.  Use the -add option to assign multiple clocks to this node.  Clock was not created or updated.
    Info (332050): create_clock -name CLK1 -period 20.0
This is also the clock which feed the pll (clk_100) as reference clock. Can you help me clarifying this issue?
I added the archive file in the attachments.
Thank you for any help.
    Somewhere, you have another constraint targeting the port CLOCK_50_B5B based on the warning you got. Whatever that constraint is is part of what's messing things up.
    The failing path report is indicating that clk_100, your virtual clock, is the latch clock for the failing path, implying that the failing path is an output path. Is this correct? Is clk_100 driving whatever device you are feeding? Check your set_input_delay and set_output_delay constraints. Make sure that the correct virtual clock is referenced in them (upstream device virtual clock for set_input_delay; downstream virtual device clock for set_output_delay).
    Maybe just post your whole .sdc! That might make it easier to figure this out.
    --- Quote Start ---
    You're using the same input port for 2 different clock domains. As the warning says, you should include -add to have both clocks input on the same port. Do you have something on your board that switches between generating 50 MHz and 100 MHz to this same port?
    divclk looks like the output of your PLL.
    --- Quote End ---
    where do you see this? In the SDC file I have:
    create_clock -name CLK2 -period 20.0
    create_clock -period 10 -name clk_100
    Clock_50_B5B is reference clock for the LPDDR2 Hardmemory Controller PLL (165.02 MHz + 330MHz). CLOCK_50_B6A is driving the 50 MHz instances on FPGA and is also the reference clock for the 100 MHz PLL.
    Is this causing me the failing path warning in time quest? How do I have to interpret the failing path? Is not the above mentioned failing path telling me that I have a skew of 10 ns which is caused with the last flopping of output data in IO_Control?
    There is no switching between 50 and 100 MHz.
