17 years ago
SRAM, external flash, why separate address?
Dear, in my design, why exteranl SRAM and exteranl flash can not share the same address bus?
chip: cyclone II EP2C35, BGA484
software: quartus II 9.0
hardware structure:
CPU -- tri state -->
--CFI controller --- external flash (512Mbits, S29GL512)
--RAM controller --- external (256kx16,SAMSUNG,KM616)
when I check the created mode in block diagram, I found SRAM and flash use two address bus and one same data bus:
address_to_the_ext_sram[18..0]
flash_ssram_tristate_bridge_address[25..0]
flash_ssram_tristate_bridge_data[15..0]
can I use "flash_ssram_tristate_bridge_address" as the address of SRAM? or shall I have to use separate address?
Thank you.
    To share the buses, the SRAM controller must be put behind the tri-state bridge. Then if you double-click on the tristate bridge you can select which signals should be shared between the peripherals and which ones shouldn't.
