10 years agoSome issue on FT2232H in Synchronous FIFO
Hello everyone!
I have some troubles with the FTDI chip. I use it in this way: FPGA+FT2232H on custom board and PC Application on the other side. All stuff using in Synchronous FIFO mode. So from now I’m trying to send a byte command from FPGA and catch it in the windows application. And here is the problem. I didn’t saw errors or warnings it just not working. Maybe someone have the same problem as I have. Well here is my VHDL code in the key of write operation(all ports have the same name as in the datasheet):WRITE_STR: process (CLK, TXE, RST) begin
if (RST = '0' OR RD_CONTROL <= "00") then
WR_CONTROL <= '1';
data_tx <= "00000000";
elsif ((CLK'EVENT) and (CLK='1')) then
if (TXE = '0' and RD_CONTROL <= "11") then
WR_CONTROL <= '0';
data_tx <= "01101011";
else
WR_CONTROL <= '1';
end if;
end if;
WR <= WR_CONTROL;
ADBUS <= data_tx;
end process WRITE_STR; And it is simulating right as I see (pic 01.jpg). PC application. I use Visual C# 2010 i'm a new one here, so. Here is the settings after the chip is opened:
ftStatus = myFtdiDevice.SetBitMode(0x00, FTDI.FT_BIT_MODES.FT_BIT_MODE_RESET);
Thread.Sleep(10);
ftStatus = myFtdiDevice.SetBitMode(0xFF, FTDI.FT_BIT_MODES.FT_BIT_MODE_SYNC_FIFO);
if (ftStatus != FTDI.FT_STATUS.FT_OK)
return false;
ftStatus = myFtdiDevice.SetLatency(0x10);
ftStatus = myFtdiDevice.InTransferSize(10000);
ftStatus = myFtdiDevice.SetTimeouts(0, 0);
ftStatus = myFtdiDevice.SetFlowControl(FTDI.FT_FLOW_CONTROL.FT_FLOW_RTS_CTS, 0x0, 0x0);
ftStatus = myFtdiDevice.Purge(FTDI.FT_PURGE.FT_PURGE_RX);
Thread.Sleep(10);
I'll trying to change Flow Control to 0x11, 0x13 nothing happened. Change TheTransferSize and TimeOuts still the same. Here writting code by clicking on button, app must read one byte:
private void button1_Click_1(object sender, EventArgs e)
FTDI.FT_STATUS ftStatus = FTDI.FT_STATUS.FT_OK;
UInt32 RxBytes = 0;
myFtdiDevice.GetRxBytesAvailable(ref RxBytes);
if (ftStatus != FTDI.FT_STATUS.FT_OK) {
textBox2.Text += "FTDI.GetRxBytesAvailable failed";
return;
Byte ByteRead = new Byte;
UInt32 BytesRead = 0;
myFtdiDevice.Read(ByteRead, RxBytes, ref BytesRead);
textBox2.Text += "FTDI.Read failed";
return;
else {
textBox2.Text += "Reading data is " + Encoding.UTF8.GetString(btRead) + " from FPGA" + Environment.NewLine; // well, for example
In the other hand if i use terminal in the Morph-IC-II Application after the FPGA is will be programmed and USB cable already plug in you can see pic 02.jpg. Can someone explane to me how does this happen?3 Replies
Example:
if ((CLK'EVENT) and (CLK='1')) then if (TXE = '0') ... end if shoud became if (TXE = '0') ... read the article.. - Altera_Forum
--- Quote Start --- Check TXE and RXF on either edge, not only on rising edge http://electro-logic.blogspot.it/2014/03/fpga-comunicazione-ad-alta-velocita_1.html --- Quote End --- Can you explain more about it? I didn't get - Altera_Forum
