10 years agoSome issue on FT2232H in Synchronous FIFO
Hello everyone! I have some troubles with the FTDI chip. I use it in this way: FPGA+FT2232H on custom board and PC Application on the other side. All stuff using in Synchronous FIFO mode. So fr...
10 years ago --- Quote Start --- Check TXE and RXF on either edge, not only on rising edge http://electro-logic.blogspot.it/2014/03/fpga-comunicazione-ad-alta-velocita_1.html --- Quote End --- Can you explain more about it? I didn't get
