12 years agoSingle Pulse in output with pulse width ibility control
Hi everyone. I have used many ways to create single out pulse with pulse width bility. So far as I know I have to use counter to count clock pulses and make the output one and zero.
I have used state machine to write my code but always there is an unwanted pulse before my code configuration. All suggestions are Welcomed. the output waveform is attached.
my code: library ieee; use ieee.std_logic_1164.all; use ieee.numeric_std.all; entity ltd_auto is port ( clk : in std_logic; data_out: out std_logic ); end ltd_auto; Architecture behavioral of ltd_auto is signal c : integer:= 0; constant a : integer:= 2; constant b : integer:= 3; type state_type is (idle, delay, zero); signal next_s: state_type; begin process (clk) begin if (rising_edge(clk))then case next_s is when idle => c <= c + 1; next_s <= delay; when delay => if (c = a) then data_out <= '1'; end if; if (c = b) then data_out <= '0'; next_s <= zero; else c <= c + 1; end if; when zero => c <= 0; end case; end if; end process; end behavioral;
The initial high is while the FPGA is being configured. Once configured the output is driven low and fires a single pulse as your state machine describes.
If you want your output to be low during configuration you have to add a pull-down resistor to the FPGA's pin. - Altera_Forum
or just create a initial delay either by sensing a button being pressed or when a counter reaches a certain value after FPGA is configured .
--- Quote Start --- The initial high is while the FPGA is being configured. Once configured the output is driven low and fires a single pulse as your state machine describes. If you want your output to be low during configuration you have to add a pull-down resistor to the FPGA's pin. --- Quote End --- Thanks for your time josyb. I have tried to change the pull-down resistor located in Pin planner but there wasn't any change in output. I would really appreciate if you be more specific with examples or extra information. I have heard of External pull-down resistor? any idea how it works? Regards - Altera_Forum
--- Quote Start --- or just create a initial delay either by sensing a button being pressed or when a counter reaches a certain value after FPGA is configured . --- Quote End --- Hi dude, Can you be more described? I have tried to use reset before rising_edge (clk) and make my output '0' but it did not work also. And because of planned usage of fpga using buttons are not easy. I want to use it in a compact place beside other devices and it could be difficult for me to use buttons. still any idea with/without buttons are welcomed. Regards
