12 years agoSingle Pulse in output with pulse width ibility control
Hi everyone. I have used many ways to create single out pulse with pulse width bility. So far as I know I have to use counter to count clock pulses and make the output one and zero. I have used st...
12 years agoThe initial high is while the FPGA is being configured. Once configured the output is driven low and fires a single pulse as your state machine describes.
If you want your output to be low during configuration you have to add a pull-down resistor to the FPGA's pin.
