12 years agoSingle Pulse in output with pulse width ibility control
Hi everyone. I have used many ways to create single out pulse with pulse width bility. So far as I know I have to use counter to count clock pulses and make the output one and zero. I have used st...
12 years ago --- Quote Start --- The initial high is while the FPGA is being configured. Once configured the output is driven low and fires a single pulse as your state machine describes. If you want your output to be low during configuration you have to add a pull-down resistor to the FPGA's pin. --- Quote End --- Thanks for your time josyb. I have tried to change the pull-down resistor located in Pin planner but there wasn't any change in output. I would really appreciate if you be more specific with examples or extra information. I have heard of External pull-down resistor? any idea how it works? Regards
