12 years agosignal power estimation
Hello guys..
I'm trying to implement a block that evaluates the signal rms value along n samples. So, using the std definition one must do (x_k is a complex number so I have to take in account |x_k|): http://upload.wikimedia.org/math/0/1/4/014a453df92ed77eca97b228f0624d9f.png The simplier way I have in mind is to use an accumulator. By the way it will indroduce some overflow issues. There is a good way in doing this ?? Thank you !17 Replies
Thank you kaz.. I'm on it..
I've written the following code:
by the way the squared_rms is always at 'X' after the ready bit is set to '1'.. Any suggestions ?? I'm really stucked... Thank you for your time!LIBRARY ieee; USE ieee.std_logic_1164.all; USE IEEE.std_logic_unsigned.all; ENTITY rms_estimator IS GENERIC (ACCBIT : INTEGER:=10); PORT( squared_abs : IN STD_LOGIC_VECTOR(31 DOWNTO 0); clk , clr : IN STD_LOGIC; squared_rms: OUT STD_LOGIC_VECTOR(31 DOWNTO 0); ready : out STD_LOGIC; END ENTITY rms_estimator; ARCHITECTURE logic OF rms_estimator IS signal sum : STD_LOGIC_VECTOR(ACCBIT+31 downto 0):=(OTHERS =>'0'); signal i : STD_LOGIC_VECTOR(ACCBIT downto 0):=(OTHERS =>'0'); BEGIN PROCESS(clk,clr) BEGIN IF(clr = '1') THEN squared_rms<=(OTHERS =>'0'); sum<=(OTHERS =>'0'); ready<='0'; i<=(OTHERS =>'0'); ELSIF rising_edge(clk) THEN if (i=2**ACCBIT) then squared_rms<=std_logic_vector(sum(ACCBIT+31 downto ACCBIT)); ready<='1'; else sum<= sum + unsigned(pad & squared_abs); i<=i+1; ready<='0'; squared_rms<=(others=>'0'); end if; END IF; END PROCESS; END ARCHITECTURE logic; - Altera_Forum
some suggestions(not compiled)
ARCHITECTURE logic OF rms_estimator IS signal sum : unsigned(ACCBIT+31 downto 0):=(OTHERS =>'0'); signal i : unsigned(ACCBIT downto 0):=(OTHERS =>'0'); BEGIN PROCESS(clk,clr) BEGIN IF(clr = '1') THEN squared_rms <= (OTHERS =>'0'); sum <= (OTHERS =>'0'); ready <= '0'; i < =(OTHERS =>'0'); ELSIF rising_edge(clk) THEN if (i=2**ACCBIT - 1) then sum <= (others => '0'); squared_rms<=std_logic_vector(sum(ACCBIT+31 downto ACCBIT)); ready<='1'; i <= (others => '0'); else sum<= sum + unsigned(pad & squared_abs); -- what is pad? '0'? i<=i+1; ready<='0'; --squared_rms<=(others=>'0'); -- you may keep it latched end if; END IF; END PROCESS; END ARCHITECTURE logic; - Altera_Forum
Thank you kaz..
the 'pad' was not intended to be there it was written down in a previus attempt. I have not updated the 'i' signal after it equals 2**ACCBIT because for testing pourpose I want to stop the sum when the ready bit is set. By the way I always have XXXX... as output when the ready bit is set... mumble mumble.. It seems that the problem is in the recursion.. If i set: sum<=32767+sum ==> the rms is 32767 as expected - Altera_Forum
try correct the width of squared_rms (should be less 10 bits).
edit: ignore this note as it is 32 bits so is abs change sum type to unsigned - Altera_Forum
Dear kaz..
What I see is that at reset time: sum=0; Then at the first sum: sum<=sum+unsigned(squared_abs) --squared_abs=2147483647 loaded from a .dat file The result is XXXXXX and it mantains its value until the ready bit is set and de-set. After the de-setting it starts summing correctly from 0. Thank you ! - Altera_Forum
I've found the bug.. In the testbench i was not restting the input. Now it seems to work correctly. Thank you for the help kaz. You're a real guru !
Hello guys..
Now I'm working with RMS power estimation again.. I have two complex signals: sig1 and sig2. I measure the RMS of sig1 and sig2 with a vhdl block and then via software I calculate: [(float) RMS(sig1)] / [(float) RMS(sig2)] with sig1>sig2. I want that RMS(sig1) ~= RMS(sig2). So I tried to multiply sig2 with a 16-int-constant related to [(float) RMS(sig1)] / [(float) RMS(sig2)] and then take the 16-MSB after that multiplication. By the way I think I'm still missing something because I see funny results.. Any suggestions ? Thank you! have a nice day !
