15 years agoshort circuit on IO
Hello everybody
What happens when I have a CycloneII IO pin physicaly connected to GND and I drive it with logic high, i.e. a short circuit. Does this blow the FPGA or is there some protection against damage? thanks for helping. greets2 Replies
There's no protection, and the current will most likely exceed the 25 mA rating for an output pin, unless you set the lowest drive strength. In so far, the device could be damaged. By experience, I can tell, there's a good chance that the FPGA survives shorting individual pins.
For a LVCMOS output I don't think there is a protection.
What happens is that the pull up circuit is forced in an unexpected steady condition of max voltage and max current. I think that this can destroy the device but wasn't able to find confirmation with a quick search of the documentation.
