15 years agoshort circuit on IO
Hello everybody What happens when I have a CycloneII IO pin physicaly connected to GND and I drive it with logic high, i.e. a short circuit. Does this blow the FPGA or is there some protection a...
15 years agoThere's no protection, and the current will most likely exceed the 25 mA rating for an output pin, unless you set the lowest drive strength. In so far, the device could be damaged. By experience, I can tell, there's a good chance that the FPGA survives shorting individual pins.
