Serial Flash Loader Megafunction (SFL) - how to
I want to include SFL Megafunction in my project. I have created a new project for Cyclone II (EP2C20Q240) and pasted code written by fvm (http://www.alteraforum.com/forum/showthread.php?t=2472&page=2&highlight=sfl+megafunction) (thanks!).
LIBRARY ieee;
USE ieee.std_logic_1164.all;
ENTITY sfl_3c16 IS
END sfl_3c16;
ARCHITECTURE RTL OF sfl_3c16 IS
COMPONENT sfl
PORT
noe_in : IN STD_LOGIC
END COMPONENT;
BEGIN
sfl_inst : sfl PORT MAP (
noe_in => '0'
END RTL;
Of course I have generated sfl using MegaWizard Plug-in Manager. Next I ran Programmer and configured Cyclone II. After that I click right mouse button on first row and select Attach Flash Device and select EPCS. Checked Erase checkbox in the EPCS4 row. Unchecked Program/Configure checkbox in FPGA row (because FPGA was configured earlier). http://urbanowski.pl/error.jpg I choosed Start and got an error: Flash Loader IP not loaded on device 1. Operation Failed. What am I doing wrong? When I choose default SFL (sfl_ep2c20.sof) from quartus\common\devinfo\programmer directory everything works fine! So I think that there is an error in vhdl code or maybe I have not checked any necessary options in quartus (I am a newbie ;)).9 Replies
--- Quote Start --- I guess, it's rather a problem with AS related pin options. --- Quote End --- You were right. The operation of programming EPCS4 was not sometimes successful with "Enable INIT_DONE output" and "Enable device-wide output enable (DEV_OE)" options checked. So I have been testing other options. I have switched the option "Reserve all unused pins: As output driving ground" to "As input tri-stated" and my design is 100% stable and functional now. Operations of programming, verifing or erasing EPCS4 are always OK. "Enable INIT_DONE output" and "Enable device-wide output enable (DEV_OE)" options are not necessary. Thank FvM for your help! - Altera_Forum
Good, that you succeeded, but strange anyway. I've been using SFL without these pin options. I guess, it's rather
a problem with AS related pin options. But I remember, that I experienced a mysterious failure of SFL in one design. I'll check the effect of pin options ocasionally, when inplementing another design utilizing SFL. - Altera_Forum
I have solved my problem. I have checked "Enable INIT_DONE output" and "Enable device-wide output enable (DEV_OE)" [Assignments > Device... > Device and Pin Options > General] and SFL Megafunction is working now :) - Altera_Forum
I have tried Quartus 7.2 SP3, Quartus 8.0 SP1 and Quartus 8.1 without any success :(
I have no further explanation, except there may be a Quartus V8 problem.
I did all tests with Quartus V7.2 - Altera_Forum
--- Quote Start --- There may be a problem, that an unconfigured AS memory device is interfering with JTAG. The Quartus programmer has an option "Halt on-chip configuration controller" to avoid this situation. --- Quote End --- OK. But when I am configuring FPGA with "factory default" sfl (quartus/common/devinfo/programmer/sfl_ep2c20.sof) everything is ok and I have access to EPCS4 (without checking option "Halt on-chip configuration controller"). I think there is a "stupid" error in my project. But I will try to enable that option. --- Quote Start --- As a (really trivial) reason, the sof-file selected in Quartus programmer may be different from the current compiled design. --- Quote End --- No way ;) - Altera_Forum
This design should be basically equivalent to EPC2 factory SFL design.
Although my example originates from EPC3, I have also used it with Cyclone II without problem. There may be a problem, that an unconfigured AS memory device is interfering with JTAG. The Quartus programmer has an option "Halt on-chip configuration controller" to avoid this situation. As a (really trivial) reason, the sof-file selected in Quartus programmer may be different from the current compiled design. - Altera_Forum
Yes, megafunction has been compiled. Look at the screenshot:
http://urbanowski.pl/error2.jpg I have a "clean" design, without any pins or I/O assignments. - Altera_Forum
Can you see, that the SFL megafunction has been actually compiled to the configured design? It must be present e. g. in the Quartus hierarchy view. Generally, I experienced some cases, where the SFL wasn't compatible with other design elements (pin usage or I/O voltage assignment) or where it wasn't working correctly, that means not accessing the AS device. But the SFL has been always accessible by the JTAG programmer.
