17 years agoSerial Flash Loader Megafunction (SFL) - how to
Hi, I want to include SFL Megafunction in my project. I have created a new project for Cyclone II (EP2C20Q240) and pasted code written by fvm (http://www.alteraforum.com/forum/showthread.php?t=2...
17 years ago --- Quote Start --- I guess, it's rather a problem with AS related pin options. --- Quote End --- You were right. The operation of programming EPCS4 was not sometimes successful with "Enable INIT_DONE output" and "Enable device-wide output enable (DEV_OE)" options checked. So I have been testing other options. I have switched the option "Reserve all unused pins: As output driving ground" to "As input tri-stated" and my design is 100% stable and functional now. Operations of programming, verifing or erasing EPCS4 are always OK. "Enable INIT_DONE output" and "Enable device-wide output enable (DEV_OE)" options are not necessary. Thank FvM for your help!
