jAlter
1 year agoSchmitt Trigger at MAX10 PLL dedicated input
MAX 10 devices feature selectable Schmitt Trigger on all inputs. The question is if the dedicated PLL input pin is affected by the Schmitt Trigger when it is enabled, or if the PLL input bypasses the...
AqidAyman_Altera
1 year agoHello,
Based on the User Guide, I believe they should be separated for the dedicated clock input pin.
jAlter
1 year ago
@AqidAyman_Intel wrote:Hello,
Hi AqidAyman,
I'm not sure I understand exactly what you mean by "they". Note that the expression "dedicated PLL input", used in Altera documentation, is a bit misleading. It is not exactly dedicated in the sense that it can be only used for driving a PLL. It can also be used as a normal input, even at the same time that it is used as the PLL clock input.
Wouldn't be possible to get an authoritative answer to this?
