16 years agoRTL of design is different from expected
I would like to implement a freq divider by using clock enable method(clock enable signal connect to every enable pin of register in design).
however, when i write the verilog code e.g "if (clock_ena== 1 && function_ena == 1) ... non blocking statement)", the RTL viewer shows that the architecture is changed(the enable pin of register is not connected). May i know how to ask the compiler to design the way that i expected? It is because i have difficulty on write time quest constrait. thanks5 Replies
rbugalho,
If doing like this, it will lost the function of one input signal. As we know, when clk_ena is low, output will maintain the previous data. When function_ena is low, output will be low as well. Anyway, i have tried the method u proposed. I fail to find the my_clk_en. Besides, the enable pin of register is not connected to anything - Altera_Forum
Try this
(* keep = 1 *) wire my_clk_en = clk_ena && function_ena; always @ (posedge clk) begin if(my_clk_en) begin ... end end This way you'll be able to find the my_clk_en in TQ with get_keepers. - Altera_Forum
FvM, the problem i faced is the name of output of comb logic is the name synthesized by QII. I cant constraint multicycle path on the every module i have 1 one shot. Any idea on it? Or this is the disadvantage of using clock enable method?
noted. thanks
The clock enable function is usually implemented in the combinational logic. The reason for it is simple: None of the recent Altera FPGA families has a dedicated clock enable input at it's core registers, check the device manuals.
