16 years agoRTL of design is different from expected
I would like to implement a freq divider by using clock enable method(clock enable signal connect to every enable pin of register in design). however, when i write the verilog code e.g "...
16 years agoThe clock enable function is usually implemented in the combinational logic. The reason for it is simple: None of the recent Altera FPGA families has a dedicated clock enable input at it's core registers, check the device manuals.
