16 years agoRTL of design is different from expected
I would like to implement a freq divider by using clock enable method(clock enable signal connect to every enable pin of register in design). however, when i write the verilog code e.g "...
16 years agoFvM, the problem i faced is the name of output of comb logic is the name synthesized by QII. I cant constraint multicycle path on the every module i have 1 one shot. Any idea on it? Or this is the disadvantage of using clock enable method?
