Resetting FPGA before clock starts
Is there any way to initialize a Cyclone III FPGA after it has read its configuration but before the external clock starts up? My overall design uses a CPU which has to boot up and eventually I will be able to start a clock going to the FPGA. But it can take a couple seconds to get there. I want to have the outputs of the FPGA at a known initialized state as soon as possible, before the clocking begins. Any way to do that?
Hmm. Having difficulty understanding exactly what you want to do. But let's assume you've got 3 registers: reg_a, reg_b, and reg_c. They connect to your FPGA's outputs. Then, using the reset_n signal above, asynchronously reset them:
Alternatively, you could initialize all of them the way I initialized sync[2:0] above. If this still isn't what you're after, perhaps read about the DEV_CLRn pin in the Cyclone III handbook.always @(posedge clk or negedge reset_n) begin if (!reset_n) begin /* regs will take on these values before the first rising edge of clk */ reg_a <= 1'b0; reg_b <= 1'b1; reg_c <= 1'b0; end else begin /* "normal" next values for rising edge of clk */ end end - Altera_Forum
I am using Verilog and SystemVerilog. Yes, I have done something like what you suggest and it does seem to work. I just got my first FPGA hardware design back this afternoon and I was trying to turn it on. Lots of things I had never done before, like the serial flash memory for configuration, and using an external programmer to dump the configuration into the flash. It was the first time I had designed and laid out that hardware and I didn't yet know how I could do a very simple test to see if it worked.
But I did try a reset register and set it to a starting value like you suggested and used it to load a register that drives some status LEDs. And it all turned on as I expected, first time - WOW! Of course, my question was not so much how to maintain a reset for some number of clocks, but how to initialize a bunch of different registers in my design before ANY clocks have yet happened. It seems to work in the simple case I tried with the status LEDs, but I will need to apply it further to set all my outputs to a known initial state. - Altera_Forum
I speak mostly Verilog, mostly, so my apologies if you speak VHDL:
/* The initialization below will be present after configuration */ reg sync[2:0] = 3'b000; always @(posedge clk) sync <= {sync[1:0],1'b1}; /* if you want reset_n to stay low for more clocks, init a counter with sync[2] */ assign reset_n = sync[2];
