14 years agoResetting FPGA before clock starts
Is there any way to initialize a Cyclone III FPGA after it has read its configuration but before the external clock starts up? My overall design uses a CPU which has to boot up and eventually I will ...
14 years agoHmm. Having difficulty understanding exactly what you want to do. But let's assume you've got 3 registers: reg_a, reg_b, and reg_c. They connect to your FPGA's outputs. Then, using the reset_n signal above, asynchronously reset them:
always @(posedge clk or negedge reset_n) begin
if (!reset_n) begin
/* regs will take on these values before the first rising edge of clk */
reg_a <= 1'b0; reg_b <= 1'b1; reg_c <= 1'b0;
end
else begin
/* "normal" next values for rising edge of clk */
end
end Alternatively, you could initialize all of them the way I initialized sync[2:0] above. If this still isn't what you're after, perhaps read about the DEV_CLRn pin in the Cyclone III handbook.
