16 years ago
Remote Update Cyclone III from EPCS
I am able to load in an Application configuration from a specified address in the EPCS, but after a certain time the device reconfigures itself with the Factory configuration (at address 0).
I am not using a Nios processor. Reconfiguration is controlled by an external processor and a simple state machine in the FPGA.
It seems that the first time I trigger the device to reconfigure itself with the Application configuration (address 30000) it will immediately reconfigure itself with the Factory configuration. On subsequent times it will keep the Application configuration for about a minute before reconfiguring itself with the Factory configuration.
It seems like it has something to do with the watchdog timer, but I have not enabled it. I have not been successful yet in reading back the status from the Remote Update circuit so I can't tell what caused the reconfiguration. I connected a signal that has a short pulse every millisecond up to the reset_timer line but that made it such that the FPGA would revert back to Factory configuration immediately every time I triggered a reconfiguration with the Application configuration.
Any ideas on what to look for would be appreciated.
    Brunda - without knowing more about your circuit it is difficult to answer you. Is the I2C a part of an SOPC build?
    Yes,I2C is part of SOPC build.
    I2C-->Controller logic to read new image from I2C-->Update logic to write new image into EPCS-->ASMI_PARALLEL-->EPCS
    I have basically followed AN603 which is AS implementation for STRATIX devices
    Brunda - I'm a little confused as to which EPCS device you are using, you mentioned Cyclone III AS mode epcs16 which is using a serial device in Active Serial mode and connecting to it using the ASMI parallel interface.
    I'm not sure that is the right way to go unless I am not understanding something you are saying.
