16 years agoRemote Update Cyclone III from EPCS
I am able to load in an Application configuration from a specified address in the EPCS, but after a certain time the device reconfigures itself with the Factory configuration (at address 0). I ...
15 years agoBrunda - I'm a little confused as to which EPCS device you are using, you mentioned Cyclone III AS mode epcs16 which is using a serial device in Active Serial mode and connecting to it using the ASMI parallel interface.
I'm not sure that is the right way to go unless I am not understanding something you are saying.
