Rk_Athram's avatar
Rk_Athram
3 years ago
Remote system update for arria10 FPGA
we are using Arria 10 FPGA DEVICE "10AX057N2F40E2SG", we needed to use Remote system update feature for our custom board.
From the intel design store, there are two reference design modules.
But from rocketboards website it is stated as
https://www.rocketboards.org/foswiki/Documentation/RemoteSystemUpdateCompatibility
"The Remote System Update (RSU) is a feature available for Stratix 10 and Agilex FPGA devices"
please Clarify whether Arria10 will support or NO!
Rajesh
  • tehjingy_Altera's avatar
    tehjingy_Altera
    Hi Rajesh
    Did you manage to open the project Archive?
    I followed the RSU document for building all the projects.
    Jingyang, Teh
  • Rk_Athram's avatar
    Rk_Athram
    Hi Jingyang, Teh,
    I am able to open the project Archive, and regenerated the bit files and checked, and facing the same issue so i have checked with the case.zip files of your .jic and it is also not working i have attached log file please check once.
    I wonder why i am facing the same issue,
    Is updating flash with new configuration remotely worked for you !
    if working
    May i know which firmware code you are using?
    please give a brief about the set up which you were using ?
    Is it possible to have a recorded video or live demo is possible ?
    Rajesh
    tehjingy_Altera
    Hi Rajesh
    Could you please reattach the logs files?
    Jingyang, Teh
    tehjingy_Altera
    Hi Rajesh
    It seems like there is a problem with the driver module compilation and insertion.
    The example owner is OOO today and will provide you a reply once I get his input on the logs.
    Meanwhile I have attached a log of the compilation and insertion of the driver module on my board.
    Could you go through the software requirement required for the host machine? Have you gone through all the required installation?
    Jingyang, Teh
    tehjingy_Altera
    Hi
    Form the error logs, it could be a driver compatibility issue.
    Is it possible to try it out on a Centos OS machine?
    In the user guide it mention that a Centos OS Machine was used.
    2.1. Hardware Requirements
    1. Intel Arria 10 GX FPGA Development Kit.
    2. Micro USB to USB Type A cable for configuring the FPGA device.
    3. A computer with a PCIe Gen3 x8 or x16 slot running Linux Operating System. CentOS Linux 7.4 64bit was used for this reference design testing.
    4. A Windows or Linux computer to run Quartus Prime Pro software and configure the Intel Arria 10 GX FPGA Development Kit.
    In the host machine I am using is also a centos running machine:
    Operating System: CentOS Linux 7 (Core)
    CPE OS Name: cpe:/o:centos:centos:7
    Kernel: Linux 3.10.0-1160.45.1.el7.x86_64
    Architecture: x86-64
    Jingyang, Teh
    tehjingy_Altera
    Hi
    Since a solution have been provided and no feedback was received, I shall set this thread to close pending. If you still need further assistance, you are welcome reopen this thread within 20days or open a new thread, some one will be right with you. Please login to ‘https://supporttickets.intel.com’, view details of the desire request, and post a feed/response within the next 15 days to allow me to continue to support you. After 15 days, this thread will be transitioned to community support. The community users will be able to help you on your follow-up questions.
    If you happened to close this thread you might receive a survey. If you think you would rank your support experience less than 10 out of 10, please allow me to correct it before closing or if the problem can’t be corrected, please let me know the cause so that I may improve your future service experience.
    Jingyang, Teh
