Rk_Athram
3 years agoRemote system update for arria10 FPGA
Hi, we are using Arria 10 FPGA DEVICE "10AX057N2F40E2SG", we needed to use Remote system update feature for our custom board. From the intel design store, there are two reference design module...
Rk_Athram
3 years agoHi Jingyang, Teh,
I am able to open the project Archive, and regenerated the bit files and checked, and facing the same issue so i have checked with the case.zip files of your .jic and it is also not working i have attached log file please check once.
I wonder why i am facing the same issue,
Is updating flash with new configuration remotely worked for you !
if working
May i know which firmware code you are using?
please give a brief about the set up which you were using ?
Is it possible to have a recorded video or live demo is possible ?
Rajesh
