Regarding Parallel Flash Loader II
I’m planning to configure an Agilex 5 using the Avalon‑ST configuration scheme with an external host. I would like to use a Cyclone 10 LP as the host and implement PFL II, but Cyclone 10 LP does not allow selecting “FPGA Configuration” in the PFL II IP settings.
The documentation says that only MAX II / MAX V / MAX 10 devices are supported as external hosts for Avalon‑ST.
https://docs.altera.com/viewer/book-attachment/0ZDiMtPwlgEoThCi3ZWIaQ/CDJY00XzF6LJj1iBS5riOA-0ZDiMtPwlgEoThCi3ZWIaQ
Can Cyclone 10 LP be used as an external host for Agilex 5? If not, what device is recommended?
- FvM
MAX 10 is basically a good choice for PFL II implementation. There are however no MAX 10 specific submodules in the IP core. It's not clear at first sight why PFL configuration function shouldn't be available e.g. with Cyclone 10 LP. I notice that also standard PFL IP doesn't provide configuration function for other devices than MAX II, MAX V or MAX 10. This isn't congruent to PFL User Guide that tells
"You can use the PFL IP core in Intel MAX® devices (Intel MAX 10, MAX II, and MAX V devices) or all other FPGAs to program flash memory devices efficiently through the JTAG interface and to control configuration from the
flash memory device to the Intel FPGA." https://docs.altera.com/r/docs/683698/21-1/parallel-flash-loader-intel-fpga-ip-user-guide
I was able to import MAX 10 PFL II IP files to a Cyclone 10 LP design and compile without errors. Unfortunately I have no test hardware to check the function.
Frank- mario
Thank you. Is the reason why “FPGA Configuration” cannot be selected in the PFL II IP when using Cyclone 10 LP still unclear?
In general, is PFL‑based configuration not recommended when using Cyclone 10 LP?- FakhrulA_altera
Hi Mario,
Cyclone 10 LP is not an official supported external host for Agilex 5 Avalon‑ST when using PFL II. Supported hosts are MAX II, MAX V, MAX 10, or a microprocessor that streams the bitstream. Avalon-ST Configuration
Recommended approach: use a MAX 10 running PFL II to read flash and drive Avalon‑ST.
Can you still try Cyclone 10 LP as a host? Only as a custom, official implementation where you need to build the host logic yourself.Regards,
Fakhrul
