15 years agoRead/Write on Altera
Is it possible to read data from a schematic using an antenna, and display the signal on the LCD of the Altera DE2 board. For example, I am making an electric field detector. May I display the strength of the signal on the LCD? If so, how is this possible?
Basically yes. The program memory size should selected according to the intended application complexity.
So would an 8-bit PIC16F684 be suffice?
As an additional remark: You achieve nearly everything with FPGAs. But their strong point is fast digital signal processing at speeds beyond multiple MBit/s and MS/s. Processing analog measurements of a few Hz bandwidth can be most easily done with a single chip microprocessor, e.g. a PIC.
Ah, ok thank you!!
--- Quote Start --- Is it possible to read data from a schematic using an antenna --- Quote End --- I guess, you are talking about the output signal of an analog circuit. Normally you would utilize an analog-to-digital converter to acquire the signal. But DE-2 doesn't have general purpose ADCs, only dedicated audio and video codecs.
