15 years agoRead/Write on Altera
Is it possible to read data from a schematic using an antenna, and display the signal on the LCD of the Altera DE2 board. For example, I am making an electric field detector. May I display the stre...
15 years agoAs an additional remark: You achieve nearly everything with FPGAs. But their strong point is fast digital signal processing at speeds beyond multiple MBit/s and MS/s. Processing analog measurements of a few Hz bandwidth can be most easily done with a single chip microprocessor, e.g. a PIC.
