15 years agoRead/Write on Altera
Is it possible to read data from a schematic using an antenna, and display the signal on the LCD of the Altera DE2 board. For example, I am making an electric field detector. May I display the stre...
15 years ago --- Quote Start --- Is it possible to read data from a schematic using an antenna --- Quote End --- I guess, you are talking about the output signal of an analog circuit. Normally you would utilize an analog-to-digital converter to acquire the signal. But DE-2 doesn't have general purpose ADCs, only dedicated audio and video codecs.
