Sumanth
4 days agoPlease find the below signal tap waveform
The PLL locked signal is used as a reset for the Remote Update IP after inversion, and the reset is extended and synchronized for five additional cycles of the Remote Update clock. Later, a state machine checks that the busy signal is not asserted. Once busy is deasserted, it attempts to read the current configuration boot address and then the reconfiguration trigger condition. For all read operations, a response of all 1’s was observed.
Farabi
1 day agoHello,
Could you please explain what is the expected behavior you observed, and what is the not expected behavior you observed?
regards,
Farabi
