Alex02
4 years agoPossible Compatibility Issue Between Intel Cyclone 10 GX Dev Kit and Xilinx FMC-105-Debug
I am working with the Cyclone 10 GX Dev Kit and have successfully run programs on it before.
I am trying to use the Xilinx FMC to debug signals from the FPGA and eventually communicate with another...
FvM
4 years ago@ak6dn All FMC cards on the market can be expected to be in many ways pin compatible with the C10GX eval board as far as they follow the manufacturer independent open FMC standard. But there may be nevertheless incompatibilities in detail.
@Alex02 Did you try to set S5.1 to ON to disable the FMC-JTAG chain? Review the Board user manual for details.
If it's not the JTAG chain, there may be a problem of shorted power supplies, although this should never happen if the Xilinx board is designed according to the FMC standard.
Frank
