FvM
1 year agoIf .jic image has been compiled with Signaltap, the tool will recognize the image. To be sure, you can ignore the message and start acquisition. You either succeed or get an "incompatible image" message. In the latter case, you didn't manage to put the right image into .jic.
Jcole
1 year agoWould an actual Signal Tap core be better suited for this or is using just the .stp file the preferred method.
