R-Tile Avalon Streaming PIPE Direct x16: Locks COM(K28.5) Symbols correctly but some lanes do not.
Hi Jayden ,
Lane 9 appears to decode the TS2 sequence correctly. Lane 8 shows COM (K28.5) and PAD (K23.7) correctly, but the symbols after that are unstable / corrupted.
>> I see you are using x16, do you occupied all of the 16 lane ?
>> Is it only lane 9 and lane 8 got problem and other lane act as what you expected ?
>> Do you tested in gen2 ? or this issue only seeing in gen1 ?
What mode of the pipe direct you trying to perform ?
Reset sequence or speed change ?
IF I understand correctly from your case description , I assume you are using reset sequence.
IF Yes, please check the signal sequence example under
https://docs.altera.com/r/docs/683501/25.1.1/r-tile-avalon-streaming-ip-for-pci-express-user-guide/pipe-direct-reset-sequence
Please do ensure that those sequence are strictly been followed.
Based on my experience and understanding , once the system entering polling.configuration substate, the a transmitter will stop sending TS1s and start sending TS2s, still with PAD set for the Link and Lane numbers. The purpose of the change to sending TS2s instead of TS1s is to advertise to the link partner that this device is ready to proceed to the next state in the state machine. It is a handshake mechaȬ nism to ensure that both devices on the link proceed through the LTSSM together. Neither device can proceed to the next state until both devices are ready. The way they advertise they are ready is by sending TS2 orderedȬsets. So once a device is both sending AND receiving TS2s, it knows it can proceed to the next state because it is ready and its link partner is ready too.
BUT I not sure what happening with your system, perhaps checking back the reset sequence can be a good start for us.
Wincent_Altera
Hello Wincent,
Thank you for the reply.
Yes, I am using the x16 configuration, and all 16 lanes are occupied. After the reset release sequence, the link proceeds to Polling.Active and Polling.Configuration on all 16 lanes. However, the problem is that the lanes that receive consecutive TS1/TS2 correctly are not stable. The set of “good” lanes changes every time I reboot the server with the FPGA card installed. In other words, the behavior looks very random.
So to answer your questions:
- Yes, I am using all 16 lanes.
- It is not only lane 8 and lane 9. The lanes that work and the lanes that fail change after each reboot.
- At the moment, I am testing only in Gen1. This issue is currently being observed during Gen1 link training. After this is solved, my first goal is to bring the link to L0 and then speed up to Gen4.
For the PIPE Direct configuration, I am using:
- PIPE Direct 16-channel
- 1x16, Octet 0 - 8 lane, Octet 1 - 8lane
- Gen4 configuration, currently down-training and debugging in Gen1
Regarding your question about reset sequence or speed change:
At the moment, I am focusing on the reset sequence path.
I already built an RTL simulation environment and connected my soft IP in the same way as in hardware. In RTL simulation, the reset sequence itself appears to complete normally without any issue.
However, in SignalTap, I sometimes see unrealistic behavior, for example pin_perst_n_o continuing to toggle, possibly due to setup timing violations around the TX clock domain. Because of that, it is difficult to trust SignalTap captures for validating the reset sequence directly.
Do you have any recommendation for how to debug or validate the reset sequence in this situation, when SignalTap itself may be showing unreliable behavior due to timing issues?
I also have one additional question.
In the waveform shown in the following link:
PIPE Direct Reset Sequence
this is a Gen1 reset sequence, but even in Gen1, both ln0_pipe_direct_txdatavalid0_i and ln0_pipe_direct_txdatavalid1_i appear to go high.
However, in Figure 48, the PIPE Direct TX Data Path for Gen1 seems to show a format where only txdatavalid0 toggles.
Because of this, I am not fully sure which behavior should be considered correct during the reset sequence for Gen1.
Could you please clarify which one should be followed during Gen1 reset sequence?
Should I treat the reset-sequence waveform as the expected behavior, or should I follow the interpretation shown in Figure 48 for Gen1 TX datapath formatting?
Thank you again for your help.
Jayden
- Wincent_Altera4 months ago
Hi Jayden ,
If referring to the Figure 49,The pin_perst should asserted high at the beginning of the reset sequence.
Can you please show your timing report ? just want to see if the violation is valid or not (A printscreen will do)
Regarding your question on the txdatavalid shall be toggling or continuous be high, let me double confirm this on my place, get back to you shortly.
Wincent_Altera - Wincent_Altera4 months ago
Hi Jayden ,
Regarding question for Figure 48 vs Figure 49.if user need to perform reset-sequence , they shall follow figure49.
While figure48 is common practice for reference purpose only.
The reset release sequence diagram is primarily intended for the reset release relationship between the various signals For the actual data handling, the user should refer to the PIPE Direct TX Datapath and PIPE Direct RX Datapath figures. On the TX side, the tx_clkout is always at 500MHz. Depending on which speed you are in, the valid data on the TX path varies between Gen1 to Gen5 and needs to toggle accordingly On the RX path, the rx_clkout varies as per gen, so every clock cycle there is valid data between _0 and _1 signals
Hope this clarified.
Regards,Wincent
- Jayden3 months ago
Hello Wincent,
Thank you for the clarification.
I have a few follow-up questions to make sure we correctly implement the reset sequence based on Figure 49.
1. TX data and txdatavalid behavior during the Figure 49 reset sequence
My understanding is that the reset sequence is performed at Gen1 speed.
If we follow Figure 49 exactly, should we keep both txdatavalid_0 and txdatavalid_1 asserted to 1, and drive TS1 Ordered Sets on txdata[9:0] during the reset release sequence?
Or, even during the reset sequence, should txdatavalid_0 / txdatavalid_1 follow the Gen1 valid-data pattern described in the PIPE Direct TX Datapath Figure 48? I am still confused.
As far as I know, after the reset sequence is completed successfully, link training should start from Detect and then proceed toward L0 according to the LTSSM(described in the figure above), where TS1/TS2 Ordered Sets are transmitted. I am not clear at which exact point or condition we should transition from the Figure 49 reset-sequence behavior to the normal PIPE Direct TX Datapath behavior described in Figure 48 / PIPE datapath figures.
Could you clarify the expected transition timing or condition?
2. Relationship between TX data transmission and cdrlockstatus assertion
In Figure 49, it looks like there is a timing relationship between points a through h/i/j/k, where tx_clkout becomes available, powerdown changes to P0 2'b00, and TX data can be driven, and points l/m/n, where cdrlockstatus is asserted and then reset_status_n_o becomes 1.
From the timing diagram, it appears that cdrlockstatus becomes 1 after TX data transmission has already started.
However, when I observe the current behavior using SignalTap, cdrlockstatus is already asserted to 1 on all lanes before TX data starts being transmitted. (I'm afraid the screenshot i have added might now be as clear, but you can probably see that cdrlockstatus for lane 0~8 are 1's and meanwhile there are txelecidle is 0xF for all lanes & no tx valid, tx data sent since phystatus_o pulse has not been seen for all active lanes(0~8 lanes, x8 config).
Is this an abnormal condition? Or is it expected behavior, and the Figure 49 timing diagram is only showing a conceptual relationship rather than a strict timing dependency?
3. Validation request to check whether this is board-specific
Lastly, I would like to understand whether this behavior could be related to our board environment.
If I provide the .sof file, the .stp file, and a simple guide mentioning a set of sticky/debug signals that make the behavior easy to observe, would it be possible for you to run the same validation on your board and check whether the same issue is reproduced?
The main purpose is simply to confirm whether pin_perst_n_o also briefly goes low and then returns high during the reset sequence on your side, or whether this behavior is only observed on our board.
This would help us determine whether the issue is related to the IP/reset sequence itself or something specific to our board/system environment.
Jayden
- Wincent_Altera3 months ago
Hi Jayden ,
>> Do not hold txdatavalid_0/txdatavalid_1 high and do not drive TS1/TS2 during the reset‑release sequence.
>> While txelecidle_i is asserted, the PHY remains in Electrical Idle and ignores txdata/txdatavalid. TS1/TS2 placed on txdata would not be transmitted. reset‑release timing (Figure 49) shows Electrical Idle held and labels TX data as “NA” until reset is complete and the lane is in P0/Gen1.
>> During reset‑release if refer to the figure, it keep the transmitter in Electrical Idle (txelecidle_i asserted for all active lanes, e.g., 0xF for x4) and treat txdatavalid_0/txdatavalid_1 as deasserted/don’t‑care. The PHY ignores TX data while in Electrical Idle.
>> Switch to the normal PIPE Direct TX datapath behavior (your Figure 48) only after the PIPE Direct reset sequence is complete and the lane is in P0 at Gen1 and ready. At that point, exit Electrical Idle and begin link training; when you start sending TS1/TS2, drive txdata[9:0] with the ordered sets and strobe txdatavalid_0/txdatavalid_1 per the Gen1 valid‑data pattern shown in the TX datapath figure.
>> The table is something we tested internally and proven 99.9 % of the function is working well in such situation.
>> Hence, I would suggest you to follow it, except there is a special requirement on your project (who blocking you from following it).
>> from your waveform, the cdrlock2data start to be high before the phystatus is asserted. do you do the transition of powerdown from P1 to P0 ? or all the way it is P0 ?
>> I would suggest you to check directly with the Distributor's FAE on this request.
Wincent_Altera
