Question about normal differential I/O input ports pairs to Cyclone 10 GX interconnection
Hello AqidAyman,
Thanks for you patience on this question.
I am asking the structure about interconnection between CML and LVDS. CML is dirver, and LVDS is receiver. In our case, the receiver is Cyclone 10 GX device. We use its LVDS I/O pairs as the receiver.
There are CML drivers outside of Cyclone 10 GX FPGA. These drivers need to be connected to FPGA. We connect them directly refer following description:
Intel FPGA has many LVDS receivers, so we think the external CML drivers can be fed into FPGA directly according to above image indication. BYW, there are two modes, AC coupling and DC coupling. Our hardware can implement these two modes.
So my question is that can C10GX devices LVDS receivers be used as above image's LVDS receivers? I just want to confirm with Intel engineer guys about this.
Thanks again.
applicable connection scheme depends on CML driver output common mode voltage. In case if doubt, the third scheme (AC coupling with bias voltage, Vbb = 1.2V) should be implemented.
- MinzhiWang2 years ago
Hi FvM,
Thanks for you reply, we'll test and verify the hardware firstly. I hope we can discuss more about C10GX devices here.
Hello AqidAyman,
I think you can close this thread now.
