10 years ago
quartus prime lite and flex/acex support
hi,
question from total newbie.Plus-sorry for my bad english.
Is it possible to develop applications for old flex 6000 or acex 1k with quartus prime.Or i need to download and install quartus 2 9.0
best regards,
Andjelko.
    --- Quote Start ---
    What exactyl do you mean by this?
    Ive raised flex and apex problems and had very fast replies. It depends on your service level (ie. how many chips you buy)
    --- Quote End ---
    Agree with Tricky. The support level that you have will determine the support priority.
    Thank you for reply.I will try to start with some ic supported with QII prime.
    --- Quote Start ---
    Since it is about very old device, I think it would be of very low priority in MySupport.
    --- Quote End ---
    Alex is right, this is an museum based product, and most of the resources like document, tools are aim for newer generations products.
    It is possible, yes.
    However, Quartus doesn't support these families - I'm pretty sure it never has. You need max+plus ii (https://www.altera.com/support/support-resources/download/legacy/maxplus2/dnl-baseline.html). Note: this is very old software, it needs a license, and has restrictions as to what operating systems it supports.
    Do you have a good reason for using FLEX/ACEX? I strongly recommend you consider a much newer family.
    Cheers,
    Alex
    I dont think the latest QII prime supports these devices since they are quite old. You would need to use the old QII version which has them supported.
