student8
2 years agoQuartus fails at the Fitter stage, with the following error message. How should I resolve this?"
Error (170143): Final fitting attempt was unsuccessful Info (170138): Failed to route the following 2 signal(s) Info (170139): Signal "tic:tic4|WideOr4~0" Info (170139): Signal "tic:tic6|stop_delt...
TingJiangT_Intel
Contributor
2 years agoHi there, is there any updates on this?
- student82 years ago
Thank you for your reply. I tried your suggestion, and it indeed helped with the layout and routing, making some previously unsuccessful routings successful. However, it worsened the timing. This might be an area where a trade-off is necessary.
