student8
2 years agoQuartus fails at the Fitter stage, with the following error message. How should I resolve this?"
Error (170143): Final fitting attempt was unsuccessful Info (170138): Failed to route the following 2 signal(s) Info (170139): Signal "tic:tic4|WideOr4~0" Info (170139): Signal "tic:tic6|stop_delt...
TingJiangT_Intel
Contributor
2 years agoYou may try to disable the "optimize timing" setting in Advanced Setting (Fitter) and see if it will help the routing process.
