student8
2 years agoQuartus fails at the Fitter stage, with the following error message. How should I resolve this?"
Error (170143): Final fitting attempt was unsuccessful Info (170138): Failed to route the following 2 signal(s) Info (170139): Signal "tic:tic4|WideOr4~0" Info (170139): Signal "tic:tic6|stop_delt...
TingJiangT_Intel
Contributor
2 years agoYou can check whether the clock frequency in your design is relatively high, and whether there are signals with large fan-out and large data bit widths. These factors can lead to concentrated routing
student8
2 years agoThank you for your reply.
My data has a maximum bit width of 40 bits. I am not sure if this is considered wide data. Moreover, from the fitter report, there are no large fan-outs except for the clock signal. If there is a way to view all fan-out situations from other locations, please let me know.
