student8
2 years agoQuartus fails at the Fitter stage, with the following error message. How should I resolve this?"
Error (170143): Final fitting attempt was unsuccessful Info (170138): Failed to route the following 2 signal(s) Info (170139): Signal "tic:tic4|WideOr4~0" Info (170139): Signal "tic:tic6|stop_delt...
student8
2 years agoThank you for your reply. The file attached below is the code for the tic module. The purpose of this module is to accurately measure the time interval between the arrivals of two levels. Could you advise on how to optimize the code to improve timing and layout? The rest of the project files are proprietary to the company and cannot be released.
- student82 years ago
LCA4 is a 4-bit carry-lookahead adder.
