16 years ago
PWM signal problem
could someone explain a strange problem with PW signal. The signal period is 30 ms, and PW triggers in between 0.7 and 2,2 ms.
But, I'v got a problem since the moment the signal rise it falls down again just like in the following picture.
http://img396.imageshack.us/img396/7549/pulse.png
I wonder if I have to assign special characteristics to the output pin in Quartus pin assignment sheet. I think VHDL code is ok. Perhaps some silly thing I overlooked.
    So the high pass time constant is in a 100 us Range. When I asked for the waveform scaling, I also referred to the voltage (level of wide noisy line and peak-to-peak value.)
    If I understand the trigger level display correct, the base line is around zero and the negative peak is actually below zero. A level, that can never be driven actively by a FPGA I/O that's really connected to this signal. You could pick it up instead from an unconnected trace running directly beneath the driven signal.
    If the probe is known to work correct, you may be probing a wrong pin. check the neighbours too.
    FvM, I think the board is faulty. But one more thing before I finalize my conclusion: what about this signal produced by VHDL single counter and no signals in sensitivity list. The peak to peak is just 10 - 12 mV. Have I done something wrong or do I miss something ?
    http://img128.imageshack.us/img128/2865/pulse3.png
    It seems to be basically the same issue of a capacitive coupled signal. Because of higher frequency, you see (almost) a square wave now. The problem is neither related to VHDL, sensitivity lists nor FPGAs in particular.
    P.S.: You may want to start by assigning a static DC level ('H' or 'L') to some output pins and trace it with a multimeter. FPGAs have, by the way, a trivial method of disabling all outputs by enabling the global DEV_OE pin in device options without asserting it. You should exclude this option, too. Also supplying no VCCIO to a bank may possibly have similar results.
    Daixiwen, batfink, FvM , thank you very much.
    I found the problem. It was a short patch of wire between the board pin and probe. I totally neglected its significiance , very silly me who did not think it can cause such an attenuation.
    Now when I checked the pin directly, the signal is perfect with no noise and with perfect shape.
