17 years agoPWM signal problem
Hello, could someone explain a strange problem with PW signal. The signal period is 30 ms, and PW triggers in between 0.7 and 2,2 ms. But, I'v got a problem since the moment the signal...
17 years agoDaixiwen, batfink, FvM , thank you very much.
I found the problem. It was a short patch of wire between the board pin and probe. I totally neglected its significiance , very silly me who did not think it can cause such an attenuation. Now when I checked the pin directly, the signal is perfect with no noise and with perfect shape.
