17 years agoPWM signal problem
Hello, could someone explain a strange problem with PW signal. The signal period is 30 ms, and PW triggers in between 0.7 and 2,2 ms. But, I'v got a problem since the moment the signal...
17 years agoSo the high pass time constant is in a 100 us Range. When I asked for the waveform scaling, I also referred to the voltage (level of wide noisy line and peak-to-peak value.)
If I understand the trigger level display correct, the base line is around zero and the negative peak is actually below zero. A level, that can never be driven actively by a FPGA I/O that's really connected to this signal. You could pick it up instead from an unconnected trace running directly beneath the driven signal.
