Programming S25FL256 through Cyclone 10 with file from Processor
- 2 years ago
signaltap waveform shows that you don't understand Avalon MM timing requirements. We see e.g. mem_read active while mem_ waitrequest is asserted which must never happen.
Imagine that mem_write starts a serial flash cycle with adress and data bits. Waitrequest indicates ongoing serial interface activity, next memory read/write can't happen before waitrequest is release. Similar problems exist with csr interface.
Hi Jcole,
I noticed that you have marked the above comment by our fellow community member, FvM, as the solution. Assuming your question has been addressed, I will now transition this thread to community support. If you have a new question, feel free to open a new thread to receive support from Intel experts. Otherwise, community users will continue to assist you on this thread. Thank you.
